I would like to be able to have a view to all settings during run, meaning having the option to check in the configuration area all settings in a "view only mode". E.g. CFD is running, I would like to see if the flow rate is correct, or the solver setting is done etc. So an access to all menues during Simulation would be great, that you can see all possible variable sets which are then blocked as view only, of course.
kippo
