Showing results forĀ
ShowĀ Ā onlyĀ
Search instead forĀ
Did you mean:Ā
Delayed reply here but this should be in the Forums and not Ideas section This is also likely due tot he fact that the external air domain encompasses the openings for the radiator. There are methods around this but the most simple is to make sure that the air domain doesnt overlap the water inlets, build an air volume that only overlaps the tubes/fins and not the inlets/outlets
