how to solve the two different materials are touching
I create a radiator and apply the copper tube, the fins are aluminum and water through the tube flows.
the external volume material is air, the boundary conditions are fixed then I move to solve the error, and the notification is the popup
1 Comment
apolo_vanderberg
Autodesk Support
Delayed reply here but this should be in the Forums and not Ideas section
This is also likely due tot he fact that the external air domain encompasses the openings for the radiator. There are methods around this but the most simple is to make sure that the air domain doesnt overlap the water inlets, build an air volume that only overlaps the tubes/fins and not the inlets/outlets
