Generative design for CFD
There is an idiea to implement generative design in to Autodesk's CFD software. For example,  insteaf of spending enormous amount of resources and time on selecting the aerodynamic design of an aircraft, user can only set the desired basic characteristics of the flight dynamics, carrying capacity and flight range of the Aircraft to the mentioned software.  After that actions Generative design software will output several aerodynamical designs of aircraft after which the user will be able to choose the most satisfactory solution. It is important to mention that  this method of designing can be applied both to the design of the entire aircraft and to its individual parts such as the wing, tail, engine nacelle and fuselage.
Currently I am working on application which allows User to generate subsonic wing design for aircraft using minimum input information for wing creation. Here is link to it https://sites.google.com/view/farid-suleymanov-portfolio/visual-basic-project?authuser=0
