Unable to connect to the selected server computer
kim.junyel
kim.junyel
Hello everyone,
I am doing a simulation for my 20 variations and suddenly this appeared. I paused my former simulation. It is working then I changed the design since there has been an error. And after trying to click solve this happened.
I am not doing a remote solver. This is my solve dialog box. Do any of you had the same problem? Thank you.
marwan_azzam
kim.junyel
Thank you @marwan_azzam it worked. But my view cube is missing. I do not know where to activate it but I can click the cube.
marwan_azzam
For the navigation cube issue you can try the following:
emove the CFD User Preferences by doing the following:
  1. Stop Autodesk CFD if it's running
  2. Delete the folder C:\Users\username\AppData\Local\Autodesk\CFD 2021
  3. Start CFD
If that does not work, I would update the drivers for your graphics card.
Marwan
kim.junyel
Will try it as soon as my study stops. Thank you so much for always attending to my concerns, Sir @marwan_azzam !
