Trouble importing geometry to CFD
I made an assembly geometry on CAD, I tried to import it on different format.
I got the same problem each time the software tell that the interference are not applicable then when I continue I can't see the full geometry only one solid part. You can read below what I got in the dialogue windows : Is it possible to know what could be the problem in this geometry?
Creating native model...
Model file read.
Assembly model generated.
Invalid analysis model detected after import.
There were 1 topological errors detected.
Design model loaded.
Building display model...
Display model complete.
Performing full diagnostic sweep...
The edge merging tool may prove useful for this model.
The small object removal tool may prove useful for this model.
Diagnostic sweep complete.
License check.
License check complete.
Performing partial diagnostic sweep...
Diagnostic sweep complete. "
the error means that there is some topological issue and the import stops, so usually there are missing parts and you will never see the void fill.
Mostly it can be sorted out with this:
http://help.autodesk.com/view/SCDSE/2017/ENU/?caas=caas%2Fsfdcarticles%2Fsfdcarticles%2FModel-import...
I've tried a little but it seems in your case the issue is not related to tolerances but rather to the modelling itself. Try to suppress some parts or cut the whole model into pieces to locate it...
