CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
thickness layer
7 REPLIES 7
Message 1 of 8
Miyuki.Azukira
344 Views, 7 Replies
thickness layer
I am new and still not familiar using CFD Autodesk. I have question, can anyone help me how to create thickness layer or extrude mesh like the picture below?
Thank you for your attention.
7 REPLIES 7
Message 2 of 8
Jon.Wilde
in reply to: Miyuki.Azukira
This looks fairly standard to me. They might have just added a few layers, so something like this (Wall Layers within the meshing) should give you a few additional layers.
The wall layers are prismatic like default.
Message 3 of 8
Miyuki.Azukira
in reply to: Jon.Wilde
Hi Jon, thank you for your reply. I was try many time to set like that. Actually I want to create a geometry of wing with rectangle boundary then generate refine mesh near wing but coarse near the wall of boundary. Please see the picture.
The wing located centre of that geometry. I separate the boundary.
I want to set growth mesh of edge near the wing but I can not.
Thank you for your sharing.
Message 4 of 8
Jon.Wilde
It might be easier to just add a mesh refinement region around the wing. Or a few of them, this should give you a nice mesh transition 🙂
Message 5 of 8
Miyuki.Azukira
Thank you for your reply. I was tried as your advice. But I can not to solve it. I set the boundary condition like this picture.boundary.jpg
- inlet as velocity
- outlet as pressure
- side view as slip/symmetry
- other side view as periodic (because I just create half of geometry)
- top and bottom side I want to set as wall but there is no option for wall so I am not set that and also the wing
then I want to solve this geometry, suddenly appear the warning like this.warning.jpg
Could you give me some advices? Thank you for your help.
Message 6 of 8
matt.bemis
Hi @Miyuki.Azukira,
The solver is exiting because the periodic boundary condition is set incorrectly. Check out this article on using periodic boundary conditions. I think in this case it would make sense to just use a slip/symmetry BC instead of periodic.
Please let me know what you think!
Matt Bemis
Technical Support Specialist
Message 7 of 8
Miyuki.Azukira
in reply to: matt.bemis
Hi @matt.bemis, thank you for your reply.
But to reduce computational I create half of that like the picture previously.
So it is better to set the BC from periodic to symmetry? what about BC of the bottom and top? I want to set as wall, but there is no option for wall. Does no need to be initialized?
Let me know if I am wrong. Thank you for your attention.
Message 8 of 8
matt.bemis
Hi @Miyuki.Azukira,
You definitely want to use the symmetry boundary condition, not periodic. The slip/symmetry BC allows the flow at the wall to be the same as the free stream velocity (upstream flow, here it'd be your inlet BC). By assigning the slip/symmetry BC there will be no boundary layer near the wall.
If you do indeed want to model a physical wall, then no boundary condition will be necessary. The flow will have a 0 velocity at the wall and a boundary layer will develop.
I hope this helps!
Matt Bemis
