Can anybody suggest idea or webpage so that I can make proper settings to the natural ventilation model that I am attempting to work with. If you see the attached image, there is a velocity field map on the XY plane and a temperature field on the XZ plane. I have only entered the temperature, air velocity as boundary condition (BC) in the inlet of the model. I have few electrical appliances inside the building. I applied heat flux BC to those appliances, but I am not able to see any change in the air inside the building, or is it usually negligible. And, how do we take solar radiation into account, I know we have to turn on the radiation 'on' option in solve window, but how can we be specific with a location? Thank you in advance.
The internal BC's, are you assigning these to a surface or a volume?
Do you have a P=0 at the outlet?
Once you have radiation on, you can then enable Solar Loading and set up the model orientation and sun's position.
Do you have gravity on?
Jon
Thanks Jon for such a quick response. I have the P=0 at the outlet. I can now set up the solar setting. I have the gravity on. Apart from that, can we check or show effective cooling caused by the wind flow in the model? I was unable to see any temperature gradient (in the final temperature map of results that can be seen in the first post's in text image) inside the building I am working on. I hope you understand my point. I am attaching my file, please take a look at this and help me. This study is for an educational purpose only.
No problem.
We would need a support file (CFZ) to view your set up.
You do have internal BC's as you said you have heat loads 🙂
Are these assigned to volumes? They do need to be, rather than surfaces.
Cheers,
Jon
