When listing surface resistances in the summary file, it appears that the Part ID starts with the first available integer assigned to all of the part volumes.
This in no way matches the actual surface id that the resistance is assigned to in the model tree, so there is no way to cross-reference the two and identify which surface resistance is listed in the summary file.
Hi @markdeckerZBQL7,
Thanks for letting us aware of this. It looks like this is indeed an issue. I originally thought it may have been from the CAD connection (original CAD is Spaceclaim), but after doing some testing it looks like this issue persists regardless of where the CAD originated from. I have built a simple model to reproduce the issue and logged the issue with our QA team.
Let me know if you have any questions.
