Summary Image issue
Summary Image issue
christerln
Summary Image issue
christerln
Hi, im using CFD2026, and i have 2 designs with small adjustment to the size of one pipe.
When i press the summary image button and go to the decision center and update the image, one image is the correct image (example: Plane of velocity) and the other image is not the way it shows in result panel. Ive tried several times to fix it, but it does not work, anyone else encounter this problem?
Any solution to fix the problem?
sherri54labrecque
Community Visitor
Community Visitor
This often happens because the display settings (like cut plane position, legend, or part visibility) aren't consistently captured or applied across all designs when you update the images. To fix this, meticulously set up your desired "Plane of velocity" view for each design in the results panel, ensuring identical settings, then individually re-capture or update each summary image in the Decision Center. Also, verify consistent part visibility and consider updating your graphics drivers or checking Autodesk's forums for specific bugs.
