Stack effect test
Stack effect test
eng.abass5
Stack effect test
eng.abass5
i am trying to test stack effect and the effect of opens shape
body to the right is static air in the meddle solid material has opens , to the left
there is a a forced air, i expected that the air will flow from right to to the left volume
under the pressure and temperature difference between right and left volumes.
unfortunately, air flows from left to the   right,
could you please check the model, the material properties, and the boundary condition
and if there is any way to make this thing happen
eng.abass5
actually it works,
but still need to know it there is any concern about volumes sizes
matt.bemis
Hi @eng.abass5,
Glad to see the air is flowing in the expected flow direction. The results look good- lots of upstream/downstream entrance length, the results look mesh independent, and the results/gradients seem fully converged. Nicely done.
Matt Bemis
Technical Support Specialist
