Announcements
Software Problem
Ahmad_Kinan
Software Problem
Ahmad_Kinan
Hello everyone,
i'm having the following problem with the program, when i try to open a saved file with results, the following massege is shown :
" File can not be opend
check the following:
1. file and folder authorization
2-Hard drive Storage
3-firewall- and security settings
and when i run a simulation, it stops before i starts to solve and shows this message :
" the analyse was stopped, because the solver has been unexpectedly stopped"
what could be possibly the reason, can anyone help?
thanks
best regeards
Ahmad
karol.suchon
Hello Ahmad,
please let me know if you have in the simulation Heat Exchanger or Centrifugular blower type material.
Also please check if you save the data on the local disk or on the network disk.
Best regards,
Karol
Ahmad_Kinan
Hallo Karol,
first i'd apologize for my late respond, i had a lot of pesonal troubles.
regarding my modle, it is a heat exchanger for electrical motors, and in those tubes a cooling medium shall be flowing, and i'm trying to simulate it to test the quality of flow.
i'm working on the university computer and it was saving all the files in netwoek disc, it is troubling because there si no space lefr and i don't know if i can save the data on a local desk.
thanks
best regards
Ahmad
karol.suchon
Ahmad,
so we know the source of the first issue, with that I could only suggest you replace the heat exchanger with a pair of simple boundary conditions, depending on the HX type that will look different so let me know what exactly you need to apply.
I am not sure about the second issue, it could be connected with simulation settings, but you do not have anything special in simulation to not allow the software to run.
If you could make a simple test, create the simplest possible file and try to run it.
If there will be the same problem the issue is connected to saving the data on the network disk.
After confirming the issue, we will try to solve it 🙂
best regards,
Karol
marwan_azzam
Hello Ahmad,
Karol's suggestion to create a simple model and run it from the same network location is an excellent idea to eliminate the possibility of the network drive being the cause.  This is often the case because of I/O issues communicating with a network drive.
To elaborate on the Heat Exchanger issue: You are trying to model a heat exchanger but are you actually using the Heat Exchanger material in CFD?  The image above suggests you're not.  Please confirm.
regards,
Marwan
Ahmad_Kinan
Hello Marwan,
no i'm not using the Heat Exchanger material in CFD, what i meant that this Structure is for a Heat Exchanger, in these tubes a cooling medium is pumbed, so there is no complicated physical model, but the geometrie is, i'm setting the boundary  condition to pressure at one side (as inlet) and from the other side is volume at the outlet, not sure if it is the best setting, i want to check how even the flow distirbution in 12 tubes.
regarding the crashing problem, it is still not clear to me, but it is most likely to be a network and storage issue.
you can see in the following foto the situation with storage, currently all data are beeing saved on the "Windows C" drive, not on storage the is specified for me "uzmtj" (on the right), i had to delete old simulation files because the were to big, especially the mesh files.storage.PNG
thanks.
best regards.
ahmad
marwan_azzam
Hello Ahmad,
Thank you for confirming that you're not using a Heat Exchanger material.
At this point I would save the model straight on the C drive and try to run it.  If you still have issues please post the support share file (*.cfz) in a zipped format.
A Pressure BC at inlet and Flow Rate at outlet should be fine.
Marwan
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
