simulate propeller in ocean
dbsxorn96
dbsxorn96
hi guys i want to simulate propeller in ocean
so i need 3d propeller. so i make that 3d propeller in cad and i convert to iges.
but i cant give motion to propeller so i cant simulate.
what is the problem i really dont know the reason help me plz!
the file is dwg cuz i cant add iges file sorry about that...
karol.suchon
Please pack the CFZ file into a zip file and attach it again.
best regards,
Karol
dbsxorn96
thanks the reply carol!
this is full file in cfd!
i really thanks to u!
karol.suchon
in the file, it looks like you applied the movement but you do not apply the centre of the rotation. So the movement will be rather weird.
There is also one additional issue, in your original geometry the element is far from the coordinates system, and the software could have problems with properly computing the centre of the rotation. The accuracy of the operation will be low. In that case, open a model in CAD software and move the propeller to the centre of the coordinates system.
You also should increase the outer volume to compute the flow properly and create some refinements region. In another case even if you run the simulation the results will be far from true.
dbsxorn96
thank u carol! i resolved that problem! so i can simulation in cfd.
haha i really thanks to that. but now i have the only problem.
if u don't mind can i ask about that problem?
that problem is the boundary condition. i only add pressure 98000pa.
but what i want to simulate that is in generator. if u don't mind then see that attach file
karol.suchon
No problem 🙂
First, you need to create the geometry, I think that it is not a necessity to apply more volume than the hole in the concrete body. Something similar to the case below.
If that is the turbine we should apply the conditions which allow us to absorb the energy from the fluid, so probably you will need to apply the pressure difference on both sides or inlet flow and pressure on the outlet. The turbine is close to the water level but I think that we could ignore the potential waving on the surface generated by the turbine.
By the way, computing the turbine is a rather complicated operation and requires a good mesh creation which the motion model is not able to achieve. So will propose using the rotating region simulation
Best regards,
Karol
