Announcements
Rotating Permeable Shell
joerg_keller
joerg_keller
Hello all,
I'm new to Autodesk CFD and need to simulate an rotating roll with a perforated shell. Vacuum is applied to the inside of the roll.
For modeling the perforated shell, I've assigned a resistance to the surface (with Through-Flow K Factor). This has worked so far. However its not possible to assign an (angular) motion to the surface. As far as I know, a motion can only be asingd to an solid.
But its not possible to assign an resistance to a (rotating) solid, so its completely tight.
So my question, is it possible to simulate a rotating, permeable shell? Or are there any workarounds?
Thanks in advance
BR
Joerg
Replies (0)
