Propeller Geometry That I Made With Fusion360 Can't Detect Cleary on Ansys
fpsundari
Observer Observer
Message 1 of 1
fpsundari
Observer
Observer
I need help.
I made a propeller geometry with Fusion360. When i try to use it for CFD analysis with Ansys, it can be read on Spaceclaim, but when i made a meshing the propeller is not detected. Am i do a wrong step? I'll describe my workflow below. Anyone please help me 😔
Fusion workflow:
1. Import STL file
2. Draw many airfoil with "create mesh section" and edit the sketch
3. Make a solid with loft, the guide rail automatic appear when i choose all of the airfoil sketches and i used it with ofcourse with adjustment until the propeller shape as similar as possible with the STL.
4. Export to iges and step
Workflow for ansys
1. Import geometry
2. Edit with spaceclaim (there are rotating, stationary, and boi). I remove the solid of propeller because i dont need it for analysis (i was try with other propeller from open source and it works)
3. Meshing (the wall_propeller can't compute)
Replies (0)
