Problem with convergence plot / Automatic Convergence Assessment wrong?
fabian.franceschini
fabian.franceschini
Hello guys.
So here is my conflict.
After 353 iterations Autodesk CFD 2019 automatically stopped calculating, since the option Automatic Convergence Assessment was on.
I ran some more iterations, to ensure that the result is really convergenced out.
Shockingly, the result after the 353 iterations is not convergenced.
What is wrong here?
Should I make even more Iterations or just take the result at 353 iterations?
I am highly confused and if someone could help me out that would be great!
Any help is appreciated.
Fabian
tomasz.kasperek
Autodesk Support
Autodesk Support
Hi, @fabian.franceschini
Thank you for contact with Autodesk Support
Please try to change the settings of automatic convergence as follows:
An important is to both of operation - move the slider to right and checkmark the Edit individually position.
It allows ordering by the user to stop the analysis after reach stability of convergence.
Best Regards,
Tomasz Kasperek
Technical Support Specialist
My Screencasts | Fusion 360 Webinars | | Troubleshooting
fabian.franceschini
The solution was running 1001 iterations. Anyways I am shocked that the Automatic Convergence Assessment stopped the calculation after just 353 iterations...
Convergence plot is now fine:
Hi @fabian.franceschini
In my humble opinion, there is no reason for you to be shocked. The Automatic Convergence Tool algorithm is not doing anything wrong here. For a closer look, you can focus on the variation of relevant DOF only and\or global/local monitor points. Cross-checked with Resid In and Resid Out, and you will find out that the actual level of 'convergence' reached. As a reminder, you are the one who is responsible for residuals' order of magnitude. The algorithm is triggered whenever flat lines of your choice are detected. Waiting for more digits/accuracy/additional iterations to complete is up to you according to the validation of the model you need.
