Problem: Start Simulation
oliver.frahnert
oliver.frahnert
Hello Guys,
when i want to run the simulation, the program tells me following:
Network file cannot be written.
Check if a problem occurred during mesh generation and fix existing geometry errors if necessary.
I followed the steps under fourther information. but this doesnt seem to help.
My model and mesh is shown here:
Someone have an idea?
I added the model directly with the button in fusion 360 and didnt export and import it.
Replies (21)
marwan_azzam
Where's the model saved?
Marwan
oliver.frahnert
Hey Marwan,
i saved the model (the CAD Model from fusion) in the fusion cloud
greetings
marwan_azzam
Don't.
Save it on local drive.
Marwan
oliver.frahnert
i will try, because first i tried it with a simple exported model and with that it worked
oliver.frahnert
Hey Marwan,
i tried it again with an imported modell and it still throws the same error message.
I think the information for the mesh also doesnt look right.
oliver.frahnert
Also this looks as too much for me:
marwan_azzam
@oliver.frahnert ,
Does the model mesh fine?
Can you share the CFD model?
Marwan
oliver.frahnert
Yes the model meshes fine. Where do i find the model file, because the path wich is named in the Design 1_model.txt is missleading.
marwan_azzam
Create the support share file (*.cfz)
zip the cfz file
Post the zip file
Marwan
oliver.frahnert
I try but the forum sends this message:
Correct the marked errors and try again afterwards.
The content type (application/octet-stream) of the attachment thermal-simulation.cfz does not match its file extension and has been removed.
marwan_azzam
@oliver.frahnert ,
Good. You got 1 out of 3.
Let's shoot for 3 out of 3.
Marwan
oliver.frahnert
Sorry total brain afk 😄 Here you go
marwan_azzam
Hi @oliver.frahnert
1- Simplify the geometry a bit (get rid of some of that details (slots) in the frame.
2- Rotating region is wrong. Get rid of parts 4, 6, & 22 and replace with a simple shape and make that an internal fan.
Marwan
oliver.frahnert
To 1:
With simplify you mean those tools? Or simplify the mesh? What should i do for second?
To 2: This needs to be done in fusion i assume?
marwan_azzam
@oliver.frahnert ,
All the changes should be done in Fusion.
Marwan
oliver.frahnert
Is this simple enough? I changed the aluprofiles and the isolation to squares and removed the fan and replaced it with a single round object. Is it really clever to replace the fan? Because then the simulation of the flowrate from the fan is not given. I wanted to make the fanblades rotating so the flowrate trough the fanholder gets simulated.
marwan_azzam
@oliver.frahnert ,
This looks good.
You will set the material of that round object to Internal Fan and set the parameters you want. This will drive the flow.
Marwan
oliver.frahnert
Does not seem to help, i still get the same error.
There are also still 1.1M elements in the mesh. 😞
This is my new support file:
marwan_azzam
Hi @oliver.frahnert ,
It doesn't make sense for the part you define as a Heat Sink to be a heat sink.
Heat sinks are usually in contact with a solid at the bottom and with air on the top with no parts attached to the top.
If you change that part to a Solid the analysis will start running.
Marwan
