problem in visualization
mandana89ghs
mandana89ghs
I have problem with visualization in result. the image is attached. there are lots of arrows and I do not know how make them disappear though global vector is set on none.
KubliJ
Hi @mandana89ghs
It looks like from your screenshot that you have a slice plane in the model. This is where the vectors are likely coming from. You can edit/remove the vectors like this:
In the vector settings you can adjust the size of the vectors and density of the vectors.
James
James Kubli, P.E.
Please marked this as solved if your question has been answered.
