CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
POINTS: .xyp Extension
2 REPLIES 2
giacomo.macrelli
368 Views, 2 Replies
I need to import a list of points (.csv) from Excel to AutodeskCFD 2016 to see the values in a specific grid.
I saw that the only command to import a file is in Result -> Planes -> XY Plot -> Read from file -> Browse
The software asks for a .xyp File that is a problem to create from .csv.
There is another way to import a list of points in the software?
Thank you!
KR,
Giacomo
2 REPLIES 2
Might the thread here be useful?
Hi Jon!
Well, I tried many times to change the extension manually but apparently, it doesn't work with Autodesk CFD 2016.
But yesterday I found an easy solution: using a .xyp file created by the software, I opened it with Excel, then I put all the data inside and I saved without changing the extension.
That's the only way to solve my issue I think.
Thank you!
