I need to import a list of points (.csv) from Excel to AutodeskCFD 2016 to see the values in a specific grid.
I saw that the only command to import a file is in Result -> Planes -> XY Plot -> Read from file -> Browse
The software asks for a .xyp File that is a problem to create from .csv.
There is another way to import a list of points in the software?
Thank you!
KR,
Giacomo
Solved by giacomo.macrelli. Go to Solution.
Solved by Jon.Wilde. Go to Solution.
Might the thread here be useful?
Hi Jon!
Well, I tried many times to change the extension manually but apparently, it doesn't work with Autodesk CFD 2016.
But yesterday I found an easy solution: using a .xyp file created by the software, I opened it with Excel, then I put all the data inside and I saved without changing the extension.
That's the only way to solve my issue I think.
Thank you!
