Natural Convection velocity plot
Message 1 of 10
Most of the time we get this kind of velocity profile. Is this correct? Region Box is created with local mesh, NAR<100, ke Model, p=0 @ top & bottom.
Replies (9)
Message 2 of 10
Jon.Wilde
Looks pretty good to me, it is surely what you would expect right?
Message 3 of 10
I was wondering if this standard configuration for buoyancy analysis is accelerating the velocity profile or not.
When buoyant rising fluid exit the top domain, solver automatically balances mass with the inlet where fluid enters from the bottom at a certain speed. This globally uprising airflow is inevitably accelerating the buoyant profile by entrainment/viscosity, isn't it?
Message 4 of 10
Jon.Wilde
This is why we have a pretty large domain, so it should be negligible.
In reality, the rising plume would also generate a flow over the unit, right?
Message 5 of 10
Yes its above enclosure. But we have very large domain compared to enclosure. More than 10 times and with box region.
Temperature flow is ok, is this velocity profile acceptable?
Message 6 of 10
True, I just had a doubt here. Thank you
Message 7 of 10
Jon.Wilde
What I can say from experience is that I have had some very accurate results using both the 'chimney' and 'bucket' approaches 🙂
Do always visit here to ask if you are ever in doubt with a simulation.
Hope that helps!
Message 8 of 10
Chimney means adding box region with localized mesh on top on enclosure right...
What is bucket ?
Message 9 of 10
I think Jon is referring to the User's guide here:
http://help.autodesk.com/view/SCDSE/2019/ENU/?guid=GUID-E0609A21-541D-4D11-9663-93476E26CF8F
Extract:
Table-Mounted
  • Model a device mounted on a horizontal surface. An example is a router on a table. (This is sometimes called the "bucket" configuration.)
Air-Mounted
  • Model a device mounted far from physical boundaries, such as on a pole or from a wire. An example is a telecommunications module suspended from a utility line. (This is sometimes called the "chimney" configuration.)
Message 10 of 10
Jon.Wilde
Very kind @Anonymous, glad you are here to help 🙂
Thank you!
