Meshing problem
Meshing problem
hanjz24
Observer Observer
Meshing problem
hanjz24
Observer
Observer
I applied a gas flow simulaiton to simple object composed of one box connected with some pipes. But the mesh is overlapped and meshing cannot go well... Is there anyone understand about this? The file is STL format, but I'm not sure it is because of the format.
p.s. what does the "unique feature" mean? I saw that during the meshing process.
hanjz24
Observer
Observer
I've solved it by using STEP file generated through Vision. And both STL files generated through AutoCAD and vision showed same problem.
