mesh
mesh
mesh
After volume and surface adjusting the mesh via the editor, I dont seem to see the number of mesh elements changing accordingly??
What is going on?
Fred
apolo_vanderberg
Autodesk Support
Autodesk Support
The "Approximate Element Count" is just that an approximation of the total number of elements based on  the geometric input and any refinements done to the model.
However, while (in some cases) the approximate may not shift in value the actual elemnt count (as reported in the Output bar or Status file) will reflect those changes.
