Mesh size
Mesh size
Hi!
I made a mesh, and run a model, but can't find the information about the mesh size. I can see the amoutn of nodes and elements, but not the minimun mesh element, for example. Can i, some how, know the size of a particular element ?
Does anyone know ?
thanks!
Tamara
matt.bemis
Hi @Anonymous,
Thanks for reaching out to us on the forums! You can find information on the mesh like fluid element count, solid element count, etc, in the Status File. This is located on the ribbon under results. I'm not sure if there's an exact way to identify the size (edge length, volume) of the largest and smallest elements. The Auto-meshing changes element size based on geometry. Figuring something like this out while using manual meshing would be a big more straightforward; the manual mesh is based on an element side length which is specified by the user. Please let me know what you think!
Matt Bemis
Technical Support Specialist
Hi Matt!
i understand what you say, and i was thinking the same. But, just know that i'm not missing something...there is no way to measure it either?
thanks for your fast reply!
Tamara
matt.bemis
Hi @Anonymous,
You are not missing anything. There is no direct way to look at an elements size.
I hope this helps clear things up!
Matt Bemis
