I have issue regarding mesh control. I have test data Flow rate vs Pressure drop. I want to find the opening of check valve. With formula I have find out the opening but in simulation when I use the calculated opening I get different pressure drop. When discussed, my colleague (who is CFD specialist but uses Ansys) told me, that in the valve there is rubber membrane, so formula might give you some value but in reality it will be different. So he advised me to change opening value in simulation till I get the pressure drop value which matches with test data and that will be correct opening. So, I am changing the opening of valve (+/- the calculated one) by keeping flow rate constant and checking the pressure drop. Now, as one can understand it will take lot of time for trial and error. So, I did the adaptive meshing for calculated opening find out potential areas where mesh should be fine. I did this, because model is very complex and number of cells are more and it takes lot of time for simulation. With adaptive I can go 1 original and next one after that cell count increases so much that laptop hangs. So, I want fine mesh only in region of interest and coarse in other.
What I want to achieve I have explained in images which one can found in zip file. I am also sharing cfz file so that you will get idea of geometry. I want to control cell size radially on circular portion of membrane. I have done following things and I am talking about effect of various settings on small gap meshing and not about meshing effect on other areas:
1) I tried to define region with auto and manual meshing. Problem is number of cells increased too much in both cases even if other areas I keep coarser. I did not get spacing finer in radial direction the way I got with adaptive mesh (please see the image for understading my requirement)
2) I tried to select respective surface and edges of the surface I am interested in and applied finer mesh still radially the mesh size is coarse.
3) I tried Surface Growth (1.05) , fluid gap (3), volume growth (1.1) one option alone and combinations also. Still generated mesh looks the same as mesh generated with default option in the interested area.
Thanks in advance! As one post said Autodesk should include Circular option for Region to control mesh size. Now I also feel the need of this option.
Best Regards,
Rajdeep Rajput
