Show only
Search instead for
just downloaded cfd2024 but have not been able to open it, when i try to open it it gives me the error matprop.cfdmdb not found. i have tried renaming the file, running the config as admin but nothing seems to have worked. please help, thanks.
The "matprop.cfdmdb not found" error can be frustrating. Here are a few steps you can try to resolve this issue:
Verify Installation: Ensure that the installation process completed successfully without any errors. Sometimes, a corrupted installation can cause this issue.
Check File Location: Make sure that the matprop.cfdmdb file is present in the correct directory. You can search for it on your system to verify its location.
Reinstall CFD: Try uninstalling and then reinstalling CFD 2024. This can sometimes fix missing file issues.
Run as Administrator: Right-click on the CFD executable and select "Run as administrator" to ensure it has the necessary permissions.
