Locate surfaces quickly & points using coordinates stated in error message
Hello Community,
1. Is there a way to locate surfaces quickly, rather than hovering over a surface and then waiting for the surface  message box to appear - a list of all of the surfaces in descending order is ideal. I have used the diagnostics tool to aid in locating surface/edge issues previously.
2. In the image attached to this post there is in the error message script a set of numbers, in this case:
 1.06633 6.19952 -5.60913 (1102).
 Where can I input or view the corresponding coordinates in the CFD software to help find the issue faster?
I am trying to remedy the problem using the suggestions mentioned in the error message dialog.
Thanks in advance.
Amardeep
Jon.Wilde
This was always my approach:
Okay, great. Is using the selection box like that on any tutorial?
Can you answer question 2 of my post?
Jon.Wilde
Sure. If you make the model Wireframe, CFD should be displaying and orange dot where the issue is.
I find this a bit hit-and-miss (unreliable) though. So another way would be to right click in the graphics window, away from the geometry and add a Monitor Point 🙂
Does that answer your question? Sorry I missed it before.
Why not using the Model Assessment Tool here?
