CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Latest Updates | New Knowledge Network Solutions | CFD
1 REPLY 1
matthew.d
1316 Views, 1 Reply
Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated for CFD?
 Subscribe to receive updates for new CFD's Knowledge Network articles.
For additional updated solutions, also check out the Autodesk Blogs!
2016 Solutions 2017 Solutions
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
1 REPLY 1
matthew.d
in reply to: matthew.d
 October 2018
Diverging Temperatures in Autodesk CFD when Simulating a Swimming Pool
Error: “The (motion) solver license could not be checked out from the license server” when launching...
Negative or unreasonable temperature results for radiation analysis in Autodesk CFD 2019.1
Transient heat flux boundary condition not working in Autodesk CFD 2019.1
How to convert between BTU/hr/ft2/R and W/m2/K in Autodesk CFD
How to Simulate a Centrifuge in Autodesk CFD
Oscillating flow behavior in Autodesk CFD for a two outlet valve model
Share file in Autodesk CFD does not contain all Design Studies
Symmetry model not matching full model for max temperature in Autodesk CFD
Pressure drop is lower than expected in CFD
Simulation hangs at iteration 1 in Autodesk CFD 2019.1 while solving with radiation
September 2018
Odd mesh growth and distribution at boundary layer in Autodesk CFD
Solver exits unexpectedly in Autodesk CFD while LMA is a result quantity
Message quantities in Project Outbox do not match the Qty shown on the Project Status report in Cons...
Error: “The Analysis has stopped because the Solver has exited unexpectedly” while using steam and q...
How to use pressure drop results to create a permeability resistance in CFD
Velocity inlet doesn’t show velocity result
August 2018
Autodesk CFD is showing non-physical scalar blobbing in a scalar mixing analysis
Exporting nodal results over all save intervals in Autodesk CFD
Pressure drop across change in direction is larger than expected in CFD
Viewing intermediate results in a transient analysis during the analysis in CFD
CFD keeping all local harddrives at 100%
Poor results while simulating phase change due to hydrostatic pressure in Autodesk CFD
Which radiation model does Autodesk CFD use?
How to capture energy balance in CFD for multi-fluid heat exchangers with variable materials
Saving a custom material to a specific database in Autodesk CFD
Model crashes when trying to open a file in CFD
July 2018
Cannot get thermal calculations to turn on/run in CFD
How to model a HEPA filter discharging as a boundary condition in Autodesk CFD
Turning the local coordinate system off by default in Autodesk CFD
June 2018
Decision Center viewport resets after changing Design Scenarios in Autodesk CFD
Visualizing results on suppressed parts in Autodesk CFD
Autodesk CFD Ultimate 2019 crashes without an error
Autodesk CFD: pressure is running away on inlet side of a rotating region analysis
CFD: Solver exits unexpectedly while using a heat sink material
External subsonic compressible flow results issues
Extracting pressure results from a surface in Simulation CFD for use in Robot Structural Analysis
Predicting turbulent pipe flow pressure drop in Autodesk CFD
System requirements for Autodesk CFD 2019
Autodesk CFD: Post processing transient monitor point data in Excel
Cut region function doesn’t work on two-byte character UI including Japanese, Korean, Chinese
Autodesk CFD 2016 vs 2018 - different results for motion analysis
Autodesk CFD CAD connection not visible in CAD package
May 2018
Fluid appears to be leaking through a solid wall in Autodesk CFD
Autodesk CFD: Motion on part with an inner body results in solver exiting unexpectedly
Autodesk CFD: Modeling pressure drop through a pipe of with a non-Newtonian adhesive
Summary Image does not retain “Set to Part” specified legend range in Autodesk CFD
April 2018
Specifying a specific solar heat flux in Autodesk CFD
What is the format of the XY plot import points file in CFD?
How to preview the mesh in CFD and see the boundary layers
How to setup a linear motion model in CFD
CFD: Calculating average velocity through a certain portion of a cut plane
CFD: Modeling the separation of two fluids
CFD: Solver exited unexpectedly while using motion surface parts
Autodesk CFD crashes when doing surface refinement
March 2018
CFD motion results in flow is pointing outward at both inlet and outlet
Can’t use Autodesk CFD while connected to ‘Cisco AnyConnect Secure Mobility Client’ VPN
FAQ for Autodesk CFD FY19 Updates
Autodesk CFD: Assigning motion to surface parts
CFD: Assigning Motion via group causes the user interface to switch back to materials setup
February 2018
Autodesk CFD: How to determine whether to use laminar or turbulent flow solver option
Conversion from imported geometry to analysis model failed - CFD
Cannot normally stop a CFD analysis running on a remote solver
CFD meshing error due to difficulties with one surface
January 2018
CFD crashes upon startup and generates a CER
CFD: External volume creation tool does not allow for necessary CAD manipulation
CFD: Global results displayed in the user interface are incorrect
CFD: Unable to launch a Cloud job when a simulation is already running locally
Autodesk CFD: Non-physical back flow into domain in free surface analysis
How to refine the mesh around small tubes portion of a CFD model
Autodesk CFD: User interface goes black and programs stops responding while viewing results
How does CFD select the stgarting operating point of a Centrifugal Pump/Blower
Modeling long term transient temperature decay in Autodesk CFD
Matt DiMichele
