CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Latest Updates | New Knowledge Network Solutions | CFD
1 REPLY 1
matthew.d
1274 Views, 1 Reply
Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated for CFD?
 Subscribe to receive updates for new CFD's Knowledge Network articles.
For additional updated solutions, also check out the AutodeskHelp Blog!
2016 Solutions
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
1 REPLY 1
matthew.d
in reply to: matthew.d
December 2017
Why is the temperature range so narrow in a CFD thermal analysis
CFD: Capturing steady state heat transfer analysis in a rotating region model
November 2017
Autodesk CFD Verification Test Model
Autodesk CFD: Assigning flow variation to a heat exchanger material
CFD: Exporting physical quantities along a particle trace
CFD: Where to find the installer of CFD Viewer 2017?
Determining building HVAC cooling requirements in Autodesk CFD
Error when exporting CFD Data Package in Autodesk CFD
Error: “The Analysis has stopped because the Solver has exited unexpectedly” before processing the f...
Heat exchanger material is meshed poorly in Autodesk CFD
Modeling air quality in an operating room in Autodesk CFD
Modeling complex electronic components which are dissipating heat in Autodesk CFD
Poor graphics performance in Autodesk CFD
Simulation diverging while using Low Re k-e turbulence model in Autodesk CFD
Temperature is not being calculated in a CFD rotating region analysis
Time step size calculator not working for rotating region in Autodesk CFD
Unrealistically slow transient conduction heat transfer in Autodesk CFD
October 2017
Autodesk CFD is diverging while using component velocity boundary conditions
CFD: Calculating pipe flow pressure drop due to wall roughness
CFD: Jobs are launched locally but never start running (Queued)
CFD: Modeling one side of a heat exchanger
CFD: Multiphase simulation gives bad results while using user-defined thermodynamic table
CFD: Should a Slip/Symmetry boundary condition be applied on the ground plane for a wind loading mod...
CFD: What does the LMA refer to?
CFD: What is the difference between the force of the wall calculator and the one of the RR result fi...
Electronics CAD takes hours to launch into Autodesk CFD
Error: “Unable to start Solver (could not upload job files)” in Simulation CFD
How to show LMA in Simulation CFD?
Modeling a car exhausting air into a garage in Autodesk CFD
Reference temperature for a convection load in CFD
Validating a multiphase flow solution in Autodesk
CFD extruded mesh works on some volumes but not others
CFD: Mean radiant temperature results are the same as the ambient temperature values on a cut-plane
CFD: Obtaining average percent liquid in a volume
CFD: Solver exiting unexpectedly while using periodic boundary condition
Boundary conditions and material assignments are lost while migrating project to a newer version of ...
Flow Design vs. Autodesk CFD
September 2017
CFD: How to assess convergence for a Rotating Region analysis?
CFD: How to extract the torque values during a local run?
CFD: How to see results on suppressed volumes?
CFD: Particle traces do not work in 2D models
CFD: The simulation of a Rotating Region is crashing in the middle of the run
CFD: Unexpected torque results from a rotating region analysis
CFD: What are the settings of the enhancement layers that should be used for the SST turbulence mode...
CFD: Where to check the mesh count while the simulation is running?
Does Autodesk CFD use the graphic card during the simulation?
Does the cloud use the CFD1 or CFD2 solver?
How does CFD2 scale from 4 to 8-16-32 cores?
Is there a way to transfer the force results from Autodesk CFD into another FEM Software?
Understanding heat transfer through an internal fan material in Autodesk CFD
Using Autodesk CFD to understand vibration forces during a fluid-structure interaction study
What Y+ values should be used for the ke and SST turbulence models?
CFD: Stop button does not end local solve
How to split up a CFD Analysis file
Low Re k-epsilon turbulence model results in the CFD Solver iterating slower
Modeling a fluid at high pressure in Autodesk CFD: compressible flow vs. scenario environment refere...
How does CFD calculate the convective heat transfer?
Autodesk CFD: use_sst_rc missing from the flag list
Autodesk CFD: Modeling AEC diffusers without using internal boundary conditions
CFD: How to apply initial condition of temperature to a volume?
CFD: How to hide the outlines of the cut-plane?
CFD: Temperature results are lower than the theoretical values
CFD: The temperature values are diverging in the middle of the simulation
CFD: The User Interface (UI) crashes when trying to export traces as .fbx file
Creating your own multiphase material in Autodesk CFD
CFD analysis converges slowly
Moldflow (Simulation products) timeout function
Setting personalized startup units in CFD does not take effect in CFD 2018
How to model baffles, registers, vents, screens, etc in Autodesk Simulation CFD
Direct import of STEP file into Autodesk CFD results in components losing their names
August 2017
How to access pressure coefficient on a wall by Python script in Autodesk CFD
Tips for setting up a motion analysis in Autodesk CFD
CFD installed in English but starts up in local language
Importing a mesh (*.nas) file into CFD causes application crash
When to include an air gap around an Internal Fan in CFD
Rounded surfaces of a model get damaged when imported into CFD
CFD: Forced convection electronics cooling analysis is diverging
CFD: Misleading units of imported Creo models
CFD: The results are not coming back from the cloud
Energy balance vs. pressure mesh independence while using mesh adaptation in CFD
How to calculate particle trace partial residence time in CFD
CFD: The number of materials in the “gbi” and “ctl” files do not match
CFD Cloud solve fails to download from cloud once the solve is completed
CFD: How to check air quality in a train station?
Graphical issues on the UI pop up when using Autodesk CFD
Applying gravity to flow driven motion in Autodesk CFD
CFD: How to model the diffusion of a fluid A into a fluid B?
CFD: Solver exits unexpectedly due to file Input/Output errors
CFD: Solver exits unexpectedly due to high memory use
CFD: Solver exits unexpectedly due to issues with CFD Server
CFD: Solver exits unexpectedly due to poorly posed parameters
CFD: Solver exits unexpectedly while running a scalar mixing analysis
Finding the maximum temperature on a plane in Autodesk CFD
CFD: Solver exits unexpectedly due to meshing problems
Post processing while using the two-phase heat transfer module
CFD: Simulating closing and opening of doors in an AEC application
Configure remote solving for CFD with computer using Symantec Antivirus
CFD: Interpreting film coefficient results from wall calculator in a Cartesian 2D simulation
Autodesk CFD: pressure and temperature radio buttons in Solution Control
CFD: Apparent energy imbalance on electronics box while using heat sink materials
CFD: Mesh between wall layers and uniform tetrahedrals are distorted and have poor quality
Error: Exceeded resources of cloud-based solver computer while solving Autodesk CFD simulation on Cl...
July 2017
Time step size for CFD massed particle tracings
Simulating a flap valve in Autodesk CFD
Strange temperature distribution during transient flow and heat transfer analysis in Autodesk CFD
Modeling a closed loop recirculation path in Autodesk CFD
Modeling a fluidized sand bed filter in Autodesk CFD
Report Generator format options in Autodesk CFD
Interpreting bulk calculator flow results in Autodesk CFD
How to create a fan curve in CFD?
How to change the license type in CFD 2018 Update 1?
Error: “Spacing # wil result in excessive grid points. Adjusting to # ” when refining the grid spaci...
Error: “The Analysis has stopped because the Solver has exited unexpectedly” while running a simulat...
Does CFD calculate the wet bulb temperature?
Capturing thermal gas expansion inside a sealed volume in Autodesk CFD
Backflow in a CFD model with pressure inlet and outlet boundary conditions
“adv5_no_dtime” flag is missing in CFD 2018
How to model an internal fan and fan guard
CFD: assigning rpm vs. tangential velocity for internal fan material
CFD: Diverging simulation for highly turbulent flow on intake manifold simulation
CFD: Do the fluid properties of a phase change analysis vary?
CFD: Energy balance worsens during mesh adaptation cycles
CFD: Is there a way to model a swirl diffuser without geometry using the internal fan/blower materia...
CFD: Obtaining average temperature values for a small volume within a single part
CFD: Setting results legend to multiple parts
CFD: Solid that is perscribed free motion is not moving
CFD: temperature decay simulation does not match experimental results
CFD: Time step is changing each iteration during free surface analysis
CFD: Time steps to run issue for transient analysis
Autodesk CFD Cloud Solving Hardware
Autodesk CFD Vs. Robot Structural Analysis
Autodesk CFD: internal fan operating point
June 2017
Error: “An axisymmetric model can’t cross the axis of symmetry” in Simulation CFD
Error: “The normal direction of an element face could not be determined because it collapsed to a li...
No heat is dissipated in external cooling of electronics box
Unit of scalar variables in Custom result quantities tool
CFD: How to set up a two phase flow analysis?
CFD: Defining a filter using a volume resistance material
CFD: Fluid is disappearing from the screen for a free surface analysis
CFD: Nodal Aspect Ratio changes during solve
Error: “The Analysis has stopped because the Solver has exited unexpectedly” before executing the fi...
Error: Unable to connect to Simulation Job Manager in Simulation CFD
Is it possible to change material properties part way into a CFD analysis
Modeling transient solar loading over an entire year in Autodesk CFD
“A valid license could not be obtained by the network license manager - Error [-5.412.11004]” when l...
CFD 2016 and CFD 2017 are showing very different results during a compressible flow analysis with he...
CFD: Advection Scheme 1 vs. Advection Scheme 5 are showing different results between two identical s...
How to eliminate recirculation at the outlets in a CFD model
Modeling plastic particulate in a manufacturing floor space using Autodesk CFD
Using a home use license of CFD
Using Fluid Energy Balance Information from Summary File in Autodesk CFD
CFD: Convergence plot in a natural convection/AEC model is unstable
CFD: The volume resistance does straighten the flow
Divergence in CFD simulation due to radiation
Time not matching up with step size and number of iterations in a transient CFD analysis
May 2017
Autodesk CFD crashes when updating geometry
CAD entity groups are not transferred from Inventor 2017 to CFD 2018 via CAD connection
CFD Centrifugal Pump/Blower with touching inlet and outlet surfaces
CFD is producing very high velocities
CFD Simulation stuck at 0th iteration
CFD: How to set up a solar heating model to evaluate the temperature on the external walls?
CFD: Over predicting flow of a centrifugal pump
CFD: Pressure drop through a long helical tube
CFD: Transient constant pressure boundary condition is in gage even when absolute is specified
CFD: Using heat sink material in areas of turbulent flow
CFD: Using thermal comfort result quantity with moist air
Error “The interface license cannot be accessed” when launching CFD 2018
Error: “The (motion) solver license could not be checked out from the license server” when launching...
Problem plotting results at points in Autodesk CFD
PTC Creo 4.0 CAD connection/direct import to CFD 2018
Unable to create an even mesh in Autodesk CFD
CFD - You do not have the necessary solver license to solve this job on the cloud
April 2017
CFD: Solver exits unexpectedly while using cylindrical volume resistance.
How to set up a spring resistance force on a motion object in Autodesk Simulation CFD
CFD: How to create a vacuum material where parts radiate across it?
CFD Error: “Analysis has stopped because the Solver has exited Unexpectedly” at meshing
CFD launcher crashes when launching CAD from Spaceclaim
CFD: Design Study Bar scenario folder is signalling results but no results are loaded in UI
CFD: How to change the language of the user interface?
CFD: Large mass imbalance between inlet and outlet
CFD: Pressure and flow rate boundary condition at inlet
CFD: Transient compressible flow with motion is diverging
CFD: Visualizing pump impeller rotation in post processing
CFD analysis stuck after last time step
CFD: Unable to load a Revit model directly into CFD
Design locked after clone & update geometry in Simulation CFD
Error: Invalid boundary condition type: velocity when trying to apply a boundary condition via a scr...
How to update a design geometry in Autodesk CFD
Importing Materials from CAD into Simulation CFD
Modeling the solidification of metal in CFD
Multicore mesher is not using the number of specified cores in CFD
Simulation CFD opens but there is no licence found when the Solve button is pressed
Temperatures applied via a CSV generated rule defaults to Kelvin or Rankin during the analysis in CF...
Can CFD estimate the runtime before starting the simulation?
March 2017
CFD: Compressible flow at an angle of attack
CFD Rotating Region analysis quits due to license issue
CFD: Natural convection in a pipe is diverging.
CFD: Obtaining bulk calculator results for every save interval
Error: The (advanced) Solver license could not be cecked out from the license server
UG NX 11 is not compatible with CFD
CFD: Wall calculator is showing very different film coefficients during mesh sensitivity study
CFD: What is the best way to capture vortex shedding
CFD: use_local_help flag is not working
February 2017
Cannot open the file error for cfz file in Autodesj CFD
CFD motion analysis not producing the expected results
Error: There are no radiation faces in the model
Meshing options are greyed out in CFD
CFD is crashing with error report on open
Can you make changes to CAD model and not lose CFD setup
Running out of disk space for results in Simulation CFD
What is the best way to model a heat pipe in CFD?
CFD: transient model is not showing room temperature at T=0
CFD: Why is there an exclamation point on a scenario in the Design Study Bar?
Cannot open a CFD file after creating a new design
CFD: How to set up a free motion analysis?
CFD Analysis generates zero velocities
CFD hangs when trying to open a model
CFD model with centrigugal pump/blower exhibits instability
CFD: Computer is blue screening during solve
CFD Pump API: Excel spreadsheet has blank values
CFD: Radiation view factor calculation occurs when radiation is turned off
CFD cooling channel analysis produces unexpected pressure
CFD Viewer shows unwanted velocity vectors
How to create a pin constraint without a cylindrical surface
January 2017
CFD 2017: Local solving does not appear in Simulation Job Manager
Divergence during transient analysis
Using a negative heat flux boundary condition
Matt DiMichele
