After Uninstalling CFD 2016 I am trying to install CFD 2017, but every time I am meeting this error. I HAVE TRIED RUNNING the setup as an ADMIN
First error "Service 'Autodesk Simulation Job Manager Local service (adsk_dssp_job_server)failed to start. Verify that you have sufficient privileges to start the system service "
Second Error "Error 1722. There is a problem with this Windows Installer package. A program run as a part of the setup did not finish as expected. Action CA2, Location: D:/AutodeskSupport\CFD 2017\\CFDConfig.exe, command: -I -S"
Do you have the full installer locally? This is a good starting point in my experience.
Then, try installing on the C drive, unless you are already?
Hey , I have the same problems. Have you found a solution? Kind regards
also I have full installer locally.
the CFD 2018
