how do I view y+ when using IWF with k epsilon model
Message 1 of 8
Hi
How do I view y+ when using IWF with k-epsilon model?
I ran a model using k-epsilon turbulence model and intelligent wall formulation.  When I tried to display y+, it showed 0 for all surfaces.  How can I assess whether or not the boundary layer was modeled correctly?
Thanks!
MArk
Replies (7)
Message 2 of 8
frederic.gaillard.7
Hello Mark,
You can enable Y+ visualisation under the result quantities in the solver tab
How many iteration did you give to your scenario ?
Thx
Fred
Message 3 of 8
frederic.gaillard.7
for k-epsilon your Y+ should lie between 35 and 350
for SST komega your Y+ should be lower than 1
hope it helps
Message 4 of 8
I'm able to visualize it now - not sure why it showed as all zero before.
Nonetheless, most of the surface of the model shows with a very low y+ (below 11). I have 5 wall layers, a layer factor of 0.62 and a layer gradation of 1.2. I would have thought I would have had better y+ values.
What is the benefit of the Intelligent wall formulation for the ke turbulence model? Does it allow for y+ values to be between 0 and 350, vs between 35 and 350?
BTW, I ran 804 iterations
Thanks!
Mark
Message 5 of 8
Thanks! Does that hold for when intelligent wall formulation is being used?
Message 6 of 8
frederic.gaillard.7
Hello Mark,
The desired values of Y+ is directly link with the turbulence used. If you use k-epsilon model, Y+ must be in that interval otherwise the pressure drop will be under estimated (Y+<35) or over estimated (Y+>350)
this is what Autodesk had to say about the Intellignet Wall Formulation
''The Intelligent Wall Formulation reduces the sensitivity of results to the level of mesh refinement along the wall. It is enabled by default for SST k-omega.''
Hope it helps
Fred
Message 7 of 8
I understand, basically using IWF doesn't absolve me from the 35-350 y+ requirement.
My y+ values are unacceptably low. My understanding is that using the ke turbulence model, I should increase the layer factor to get my y+ values up to the acceptable range. Are there any rules of thumb / methodologies as to how to adjust the layer factor, or do I just bump it up via trial and error, completely rerun the model and see what the new y+ values are?
Thanks again!
Mark
Message 8 of 8
frederic.gaillard.7
Hello Mark,
Try the basic and intermediate level and let me know how it goes.
For more information check out this video : Understanding Turbulence Model
Hope It Helps
Fred
