Help with fan inside a enclosure
I have these centrifugal blower fans, they are inside these frame:
And i want to calculate the velocity of the air entering and leaving the enclosure, specially far from it.
I have the fan CFM and inH20 pressure curve.
My question is, how to do this? Im modeling everything inside 3ds max and saving via .sat and seems to be working except i dont have any idea of how the models should be,
Currently the inlet and outlet are just very thin(.02cm) cylinder and box intersecting the box of the frame of the fan.
Inside CFM they are like this above.
And then what? What material? What material? Seems like centrifugal pump/blower is from when you model the casing itself and the cylinder that will spin... Boundaries? Internal Fan/Pump Material?
The goal is to see the air velocity outside the enclosure:
I have walls that i assign concrete to then and a box inside it that i assing fluid>air>set(variable) to it.
