Help Needed: Beginner Struggling with Simple Flow Simulation in Autodesk CFD
muca_sa
Message 1 of 1
muca_sa
Community Visitor
Community Visitor
Hi everyone,
I'm a beginner with Autodesk CFD and I'm having trouble with something that I believe should be simple. My goal is to learn how to run this simulation correctly and eventually master other techniques in the software.
I've been struggling with this, but I still haven't managed to solve it. I'm trying to create a flow from the INLET to two OUTLETS with the following specifications:
  • Viscosity: 4 Pa·s
  • Density: 1 g/m³
  • Pump Flow Rate: 60 g/min
I would like to visualize how the pressure behaves at each outlet and determine how far each fluid jet reaches. If it's possible to generate an animation, that would be even better.
Additionally, if someone could record a step-by-step screen capture of how to set this up, that would be incredibly helpful. I'll be attaching the drawing file for reference.
I really appreciate any guidance or help you can provide!
Replies (0)
