External Compressible Flow
I am trying to run an external compressible flow over a model rocket. I am not understanding why the TED and TKE aren't converging. Is there any way to help with this problem? I think this is the main reason I am having diverging problems.
I have created an external volume around the model with boundary conditions at the inlet:
T = 25 deg C
P = 0 Pa (gage)
Vel = 2232 ft/s
Outlet: Unknown
Also, should I be adding any other boundary conditions than from the ones below?
James
matt.bemis
Hi @Anonymous,
Thanks for reaching out to us on the forums! How large is your fluid domain? Did you make it following these best practices? Are you using the K-w SST turbulence model?
How do you know the turbulence residuals never converge? Does the  model eventually diverge?
Matt Bemis
Technical Support Specialist
