Exhaust Pressure in a Gas Turbine Exhaust Duct
Message 1 of 12
I am trying to determine the outlet pressure on a gas turbine using a particular ducting design. I have used the following approach:
1) Set pressure at outlet surface to 0 psig (atmosphere).
2) Set inlet mass flow rate (155 lbm/s) and temperature (1051 degrees F) according to the engine (GE LM2500) specifications.
3) Run simulation.
4) Use the Wall Calculator to determine the DP from inlet to outlet; this is my outlet pressure.
All runs smoothly, but the results seem unrealistically small (0-1 psid). I am an engineer by education, but not so smart on fluids. At this point I am using air as a medium for simplicity, but may change that once I feel like the results make sense. Given the relatively low velocities, I am assuming incompressible flow.
I have the feeling that I may be doing something wrong. The CFZ file is attached; any help would be very much appreciated.
Kerry
Replies (11)
Message 2 of 12
Jon.Wilde
It is better to use the bulk calculator near the inlet and outlet, the wall calc is really for heat transfer.
You need an extension on the inlet though, the length should be 5x the diameter. Otherwise it would be pretty tricky to capture the pressure here.
Then look at mesh refinement, as a basic setup we should have 4-5 elements across a gap, here there is only  2 at the outlet, which is not quite enough. More mesh will yield a more accurate result, this is almost always true until we reach a point of mesh independence where the mesh is so fine, more makes no difference.
You might also like to try Advection Scheme 5, at least compare it to 1. It will likely be a little more accurate also.
Kind regards,
Jon
Message 3 of 12
Jon,
Thanks for the reply. I'll give all of those a try. A related question: a plane that is aligned to the turbine outlet (the recessed circle at the bottom of the duct) will also cut through part of the ducting above (see picture below). I was concerned that this makes the summary statistics for that surface non-representative of the turbine outlet itself. Is there a way to restrict the summary to just a part of the plane?
Thanks again,
Kerry
undefined
Message 4 of 12
Jon.Wilde
No problem. You need to extend that inlet still 🙂
Within the bulk calc you should have the option to choose the surface where you want to calculate results, CFD will automatically split them for you.
Jon
Message 5 of 12
Jon,
I implemented all your recommendations, including increasing the mesh to five elements across on the outlet. The results are much more intuitive now.
Just as a check, I modified the original design by choking it off a bit at the outlet. The inlet pressure increased as expected.
CFZ file attached for anyone interested.
Thanks again,
Kerry
undefined
Message 6 of 12
Jon.Wilde
Hi Kerry,
Good to know! I appreciate this was just a quick test but to avoid avoid errors - if you do drop the outlet area down like that, it is always good to add a further extension 🙂 Nice looking image too!
OK if I mark this as solved?
Kind regards,
Jon
Message 7 of 12
Jon,
I marked your original reply as the solution.
Thanks again,
Kerry
Message 8 of 12
A follow-on question:
To analyze the INLET of a similar turbine, should an inlet extension be placed at the machine end as well? This surface would theoretically only have a mass flow boundary condition, if that makes a difference. Boundary conditions for atmospheric pressure and some assumed temperature would apply to the "open" end.
Kerry
Message 9 of 12
Jon.Wilde
Hi Kerry,
The idea of an inlet extension is to provide an opportunity for flow to develop before it enters the area of interest.
With an outlet extension, the goal is to low the flow settle, any recirculation to complete and ideally become laminar before exiting - so we avoid recirculation over the outlet. This does not change with swapping the boundary conditions. So if you don't have a uniform cross section before the outlet, extend it.
Does that make sense?
Kind regards,
Jon
Message 10 of 12
Jon,
Thanks for the clarification.
Kerry
Message 11 of 12
Please MR Jon can you help  me I have a primary level question "does improper combustion causes exhaust duct pressure(EXHAUST MANI FOLD PRESSURE) in turbines" and why
Message 12 of 12
m at: shoaibullah101@gmail.com
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
