This is my first time performing a free surface analysis. When I try to solve, I get the error message "A direction vector in the mve file has a zero length". Can anyone help???!!!
Solved by waited. Go to Solution.
Hi Anthony,
Can you zip up your cfz file and attached it to this case?
Thanks, Dave
Dave,
Sorry for the delayed response. I've attached the cfz file.
Best,
Tony
Hi Anthony,
I loaded you cfz file and noticed that you orbit axis is defined as (0,0,0), which yield the zero length that the error message is complaining about. I changed the Orbit axis to (0,1,0) and the analysis ran fine.
Dave
Dave,
Thank you for the quick response. I did not realize it required a value, as the impeller is not orbiting. Thank you for your help!
Tony
