Hi all,
Title speaks for itself; is there a published document on the Autodesk website or within the Autodesk knowledge network which states all limitations of the Autodesk CFD software? Specifically 2016/2017 releases?
Failing that, is there an expert who is able to list these known limitations? - I am planning on using it for a new project but I need to ensure that all the limitations of the software are explicitly stated and so far I have found no such list on the forums or the website.
Would be interesting to know as well, Thanks.
Luke
Solved by Jon.Wilde. Go to Solution.
Hello Luke,
A better question to pose is "can Autodesk CFD do what l'm looking for in a CFD code?"
As such, if you share with us what you're trying to simulate you can start a more productive discussion.
Did you want to add anything else here to enable us to advise you?
Here is what it can do, I would think this should help explain what it also cannot 🙂
Jon
