Crash while updating geometry from Inventor in several design studies.
I am doing some simulation on hydraulic choking valve. I want to set the inlet pressure and then calculate the flow for several height values for the orifice between the valve's poppet and socket
I did an assembly in Inventor. The poppet displacement is controlled by user defined parameter (which changes the distance in on of the contraints). Then I launch Simulation CFD and do all the setup work (boundary conditions, meshing etc.). Then I clone the design study eg 10 times.
I go back to Inventor, change the parameter for poppet displacement, update the first cloned design, then again I change the parameter and update next design...
And here is where the problem comes. When I try to update one of the designs (usually the last one) the Simulation CFD crashes while doing so. There is no Autodesk crash report, just a Windows call "the program has stopped working".
After a crash the simulation file is corrupted and i can't open it - the CFD continues crashing the same way when I'm trying.
It happens on 2014 and 2015 versions (both Inventor and CFD) and Windows 7 and fresh installed 8.1. Seems like a bug of the Simulation CFD itself.
Any workarounds at the moment for that issue? I expect a patch will be released.
Jon.Wilde
This sounds like a memory issue - have you tried just running 5 designs per project for example?
Kind regards,
Jon
Yes, i did. The number of designs doesn't matter, it can crash even with just 3, always when updating the last one.
Jon.Wilde
This is strange. There is a guide here that I think might be useful in retrieving and results that are locked into the study you cannot open.
What is your machine spec and are you able to share the CFZ?
Kind regards,
Jon
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
