Announcements
Co2 level in a naturally ventilated class room
Dear CFD users and experts,
I am trying to model a the Co2 level and thermal comfort for a classroom using a stationary model. The natural air flow depends on temperature difference (outdoor temperature = 5°C, indoor temperature = 22°C). The class room dimensions is 8 x 10 x 3 m . The inlet air has scalar 0 (air density = 1.2 Kg/m3) and the students generate scalar 1 (Co2 density = 1.773 kg/m3) There is 2 problems:
2-The resulting wind velocity is too high for a model that depends only on temperature difference (no volume rate flow,  velocity or temperature assigned to boundary conditions)
Accepted solutions (3)
Replies (14)
frederic.gaillard.7
Hello Karim,
There is few thing that are not setted properly.
First and foremost you can not have internal boundary condition :
  1. Temperature BC
  2. 0.31l/min and scalar(1)
These BC are the most problematic, they need to be removed or the mesh has to be suppressed. For the case of your inlet, removing them are not an option so the mesh need to be removed.
Can you explain the purpose of this big box of luft ?  Is this a kind of inlet ?
THX
Fred
Hi Fred,
Thanks for your reply. This big box represents the outdoor air, which goes into the room through the windows drived by temperature difference. So, when I supress the tiny boxes that represent the breathing mouthes, they will nit be calculated in mesh but they will still produce co2 (volume flow rate for scalar 1) ?
frederic.gaillard.7
Hello Karim,
Yes, they will ! See by yourself :
Hope it helps
Fred
Thanks so much 🙂
frederic.gaillard.7
Hello Karim,
let me know how the simulation goes. They are still issues with your model but this minor change will significatively improve your result.
Fred
Hello Fred,
Actually your advices helped a lot. Now the simulation took only 949 iterations, as before it didn't stop. I removed the temperature boundary conditions from the interior walls and added convection to the external surfaces. The thing is that I am very suspicious about the air velocity and temperature values. Simply what I want to do is to analyze heat transfer between outdoor (5 degree celsius) and indoor(22 degree celsius) and evaluate the co2 ppm levels in classroom, so how can I fix this indoor temperature without adding boundary conditions to the interior surface ? I added film coefficient and for exterior surfaces as well as 3 heaters (3500 W each). but still the temperature in room is not homogenous around the 22 degree celsius ! also the warm air doesn't flow upwards from the bodies of students. I apologize for the long reply but can you write me briefly the issues with this model.
Best Regards
Karim
2.PNGvelocityvelocitytemperaturetemperature
frederic.gaillard.7
Hello Karim,
You still have internal BC. I think this scenario need thermal initial condition based on your objective.
I will keep you posted.
Fred
Hi Fred,
I am really thankful for your constabt support. I just want to clear 1 point: this "Luft" box resembles the outside air. so this surface is the exterior wall of the room. actually this room doesn't have an outlet and inlet. It has only windows on one side for the inflow as well as outflow. Which boundary conditions you think I have to add to this outside air box if the flow depends only on the temperature difference (in room = 22 deg celcius and out = 5 deg celsius). also please tell me if I should have modeled the outside air in a different way in CAD.
Best Regards
frederic.gaillard.7
Hello Karim,
I was able to proprely set the temperature in both environment using thermal initial condition. However this imply that the scenario must be run in a transient mode. You can change this parameter in the solver tab under the solution mode.temperature distributiontemperature distribution
I made minor change to your scenario :
  1. Disable the scalar
    • Once the flow & thermal solution will be correctly resolve i suggest to turn on again the scalar.
  2. Add an initial temperature of 37degC to humain body
    • I add this temperature to quiclky have an overview of the termal diffusion. it can be removed if it does not suit your objectives.
  3. Supress concrete wall from the mesh
    • if there any heat loss through the classroom wall ?
  4. refine mesh near the open window
  5. switch to transient mode
Fred
Wow That's great. I have really learned a lot in this example as I was before always confused !
regarding this part " Once the flow & thermal solution will be correctly resolve i suggest to turn on again the scalar": Do you mean I run the simulation again from the beginning with the scalar on ? or to turn on the scalar and continue the simulation for more ex. 1000 iterations ?
Best Regards
Karim
frederic.gaillard.7
Hello Karim,
i'm glad to hear that you make progress.
Regarding the scalar, since your simulation is transient it will be wise to run the simulation again, from t=0sec.
I ask you to turn off scalar simply for the purpose of helping you. It is generally a faster path to succes when you gradually add layer of complexity.
I add some video of the evolution of the temperature for the first 15min inside the classroom. You don't have strong velocity field, so the TimeStepSize can be higher than 1s and the mesh does not had to be too fine as well.
How your simulation goes on your end ?
Fred
Hi Fred,
I am sorry, can you save it in 2018 version please, as it doesn't want to open since yesterday.
Best Regards
frederic.gaillard.7
Hello Karim,
i'm not sure if i can save it in a 2018 format... i will give you the big line here :
  1. Boudary Condition
    2. The most important BC for your model are located at the top of the ''cold outside'' I apply a thermal BC where T=5degC and and opening where P=0. This configuration will allow you a constant air flow at 5degC. I recommand to read the modeling strategy to have a good understanding.
    3. Set the other BC as you did in the past.
  2. Initial Condition
    2. Assign a 22degC to the air volume of your classroom. Wall and human can have a different temperature. In my previous example i applied 37degC to the humain.
  3. Mesh
    2. make sur that the surrounding of the heated body are well meshed. The common wall and the tiny opening of the window need more mesh as well.
  4. Solver Setting
    2. Switch to transient solution mode, choose a TimeStepSize.
I hope it help
Fred
Hi Fred,
the temperature and velocity simulations went well as you can see 210125_Tempratur.PNG210125_Velocity.PNGWhen adding the scalar it didn't affect the velocity and temperature but the co2 falls always on the ground, as if it is not mixed with air in one material. Here you find the result on an evaluation level from 0 till ppm as well as my input settings found on the Autodesf CFD Scalar
Again, your efforts are really appreciated.
Regards
Karim
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
