cfd simulation quits during material assignment
Message 1 of 12
Pop up Simulation CFD2015 has stopped working appears and as you try to clear this message the simulation closes. See attached Jped file. See also the attached Inventor file.
Replies (11)
Message 2 of 12
Jon.Wilde
Could you save out a CFZ from CFD before it exits and share it with us?
Can you explain what materials are you assigning to which parts so that we can try to replicate this exactly?
Thanks!
Jon
Message 3 of 12
Royce_adsk
We escalted this to a support case!  Jon should be reaching our to you directly.
Royce.Abel
Technical Support Manager
Message 4 of 12
I just now sent you the reply by email with attachments.
Hi Jon,
We are running service pack 2.
This time it failed before it could create support file ( CFZ).
However It created a support file (CFDST) which I am attaching.
I also attaching the model files so that you can run on your machine.
Once you have the model on your computer I can provide you with materials and boundary conditions.
Thank you,
Nageswara Rao Nagisetty
Senior Development Engineer
Belvac Production Machinery Inc.
237, Graves Mill Road,
Lynchburg,
VA-24502
434-832-6349
Message 5 of 12
Please see attached CFZ file
Message 6 of 12
It did not accept the cfz file as attachment
Message 7 of 12
srhusain
please rename the extension "cfz" to "zip" and repost
Message 8 of 12
here is the .cfz renamed into .zip file
Message 9 of 12
I first filled the materials and then the geometry tools; it did not fill the void.
Message 10 of 12
Jon.Wilde
Hey Syed - just a note - we are working this through a 1:1 case now and are awiaiting the CAD - there's a big gap in the model which is why it is not void filling 🙂
Message 11 of 12
HERE ARE THE MODELS
Message 12 of 12
Jon.Wilde
Hi Nagi,
Thanks for the files and feel free to just reply to the case emails (I'll send this from there also).
I cannot see any changes were made, so I suggest that the red inlets are extended out to be cuboids - so they will look more like spokes.
Should there be a leakage path as I indicated before? I suggest you close it up - why not just reduce the yellow part (starwheel) to have a diameter of 10in with an additional extrusion?
User-added image
Then cap off the inlets:
User-added image
This launches and void fills without issue.
Seems to mesh and run well, although we ought to refine the mesh to ensure 4-5 elements accross any gaps.
(I haven't worried out this to test and obviously, I have guessed the inlet/outlet/flow rate).
I suppressed any parts that were not connected to the main flow volume, there were a few on the 'inlet' side of the model.
Here are some early and rough results
Best regards,
Jon
