CFD Report Generator
Is there a way to get CFD Report Generator to give me temperatures at certain elevations within a model of a data center, say at 6 inches and 6 feet above the floor?  Thanks in advance!
Xiaojin.Zhang
Autodesk Support
Autodesk Support
Would you like to get Report generator to show temperature result at a certain plane like picture below?
If so, it is possible.
Create a plane for temperature result first. Then you can change the elevation by using Edit point on plane.
Click "Summary plane" and "Generate report". This picture will be output to "Decision center" part in the report.
Please let me know if it is not what you want.
Thank you!
Xiaojin
Xiaojin Zhang
