Hi everyone,
Yesterday I was able to install CFD 2024 on my computer. When I opened it for the first time, I immediately got the message "A material database was not found" and some instructions. Since then I have tried everything possible, renamed the specified file, run CFD Config... I have also reinstalled the whole package about seven times and also tried previous versions: Always the same message. Fusion 360 works without any problems. When starting Autodesk access, the circle spins all the time but nothing happens. I am logged in, as you can see in the top right corner...
The whole thing is an EDU licence, by the way, but everything works perfectly for a colleague.
Many thanks in advance and have a nice day!
hello,
have you managed to solve this issue as i am experiencing this also.
thanks
