Hello everyone. I am designing a hydroponic greenhouse as a university project. Along with all the other features, I am optimizing heating and cooling system doing CFD simulations. Heating is provided by fan which blows air on a PTC cell (110°) . I followed this guide ( https://knowledge.autodesk.com/support/cfd/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/SimCFD-Tu... ) to simulate this scenario and it works decently. What I am not sure about is if this way to simulate takes into accout the air motion along with heating diffusion. I mean, first I computed steady state air velocity and after a transient heat diffusion, heat spreads over the volume but the way it does looks like a natural convection rather than a forced one (the forced auto convection is set in the simulation) . I tried to simulate heat and motion simultaneously with transient simulation but I get messy results (the volume heats up but often there is strong incoherence between adiacent time steps either suddenly heation or cooling a lot ). I attach some images of the two steps simulation. Thanks for your precious help!
p.s. for a bit of context, the volume to heat is 20x30x40 cm, the initial air volume is at 20°, the fan has a volumetric flow rate of 5 m^3/h and the air taken from the outside is at 20° too; the temperature target is set at 27°-30° (the green region in the simulated plane)
