CFD Forum
Welcome to Autodeskโ€™s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
CFD Base unit?
1 REPLY 1
257 Views, 1 Reply
CFD Base unit?
I was testing some aerodynamic forces in CFD. I set the parimeters for where the wind and pressure is and my Materials. Then i "Solved" it with 150 iterations. Once that was done i "logged the Scale". I was wondering what unit does that scale log into? Thanks for the help ๐Ÿ˜„
1 REPLY 1
Jon.Wilde
you mean you changed the scale to display logarithmic?
Probably best to Google that one as it is a general term, here you go ๐Ÿ™‚
I would also suggest you view the webinar here, running for 150 iterations is going to be insufficient for external aerodynamics. It sounds as though this might be useful to you.
Jon
