CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
CFD 2019 Launch Problem: Student License
5 REPLIES 5
2541 Views, 5 Replies
Hi
I've searched a lot for solution but I don't think any of them helped. Or maybe I just misunderstood them. I am currently using ASUS G751Y with 24gb RAM and GTX 980M, but I believe my laptop is not the issue here. I attached a video clip of my problem. I really need this software for my research.
Thank you!
5 REPLIES 5
matt.bemis
@Anonymous,
This is probably a known issue due to a bad download.
https://forums.autodesk.com/t5/cfd-forum/if-you-are-having-problems-launching-cfd-2019-with-an-edu/td-p/8009774
Matt Bemis
Technical Support Specialist
in reply to: matt.bemis
Is ''browser download'' the same as ''web install''? Because that is the installer i downloaded from autodesk
matt.bemis
Hi @Anonymous,
No. They are not the same. Please see the following screencast: https://knowledge.autodesk.com/search-result/caas/screencast/Main/Details/9b086192-54ce-447f-9da3-fcd5cb7bb1de.html
Matt Bemis
matt.bemis
Hi @Anonymous,
See the attached image.
Matt Bemis
antoan4.3
Hello everyone,
If people are still having issues with CFD 2019, I've found a more robust method to ensuring that it works, especially if you're using a Education/Student License:
  • Ensure that you have removed the CFD program and residual files through this uninstallation guide.
  • Access your products through your account (click here).
  • Find the CFD product, and 'View Downloads' / 'Download Now'
  • In the download section, make sure you select the 'Browser Install' method and not the 'Install Now' or 'Download Now' method (or other methods).
  • Upon successful installation the program might prompt you for activation in which the details are found on the same page on the 'Activation' tab instead of the 'Download' tab.
For people who are new to the CFD program, I do highly recommend following a tutorial provided by Autodesk which is accessible on the tab of the home-screen of the CFD program.
I'm also quite aware a lot of people use this CFD program for the F1inSchools competition - good luck to those out there. There are easy ways to gather data from CFD instead of just using it for your own visual appeal in which case feel free to ask me.
(I do not represent as a Autodesk Staff member)
- Ant, STEM Ambassador.
