Calculate Simulation Time
Message 1 of 13
Hello Guys!
I have simple question, How to calculate simulation time based on Time Step Size, Time Steps to Run and Inner Iterations?
Here is my print screen :
Regards
Hasan,
Accepted solutions (3)
Replies (12)
Message 2 of 13
Jon.Wilde
The time run is just (time step size x time steps run).
You do need to be sure to turn of Intelligent Solution Control (in Solution Control) though, so CFD keeps the same time step sizes.
A better way might be to set a fixed stop time and just set 100,000 iterations to run. Then CFD will simply stop at the time you have assigned (in seconds).
Jon
Message 3 of 13
Do you mean "turn off" Intelligent Solution Control ?
I dont need to turn off since Intelligent Solution Control has turned off
as default. You can see in my print screen, I set time step size 0.1 and
time steps to run 5500, why is simulation time 15 seconds??
Hasan
Message 4 of 13
Jon.Wilde
That is the question 🙂
Right now I am not sure, are you running free surface or anything?
You might need to share your model...  (CFZ file).
Message 5 of 13
Yes I am using Free Surface.
This is my CFZ file:
Regards
Hasan
Message 6 of 13
Regards
Hasan
Message 7 of 13
Jon.Wilde
OK, that is the issue then. Free Surface will change the time step size to suit, so that it does not diverge.
It usually decreases it for stability.
This is why the numbers do not appear to match up.
Does that answer your question?
Kind regards,
Jon
Message 8 of 13
Thank you very much John.
Since I conducted free surface simulation and got some (not all) fails. Do I need to turn on Intelligent Solution Control in free surface simulation? Error message informed that divergence
Hasan.
Here is print screen.
Message 9 of 13
Jon.Wilde
I would leave everything as the default that is selected when you enable free surface 🙂
(ISC = ON)
Message 10 of 13
I have assigned stop time 14 but the simulation stopped at 5s. What do you
think about it?
FYI, free surface and ISC on.
Hasan
Message 11 of 13
think about it?
Hasan
Message 12 of 13
Jon.Wilde
Did CFD say that it was converged?
Maybe you need to turn off the convergence assessment so it will just keep running?
Message 13 of 13
Hello John, How are you?
I am still not able to catch water hammer phenomenon as I can not see the
oscillating water level in surge tank. I hope you have a nice trick to
solve this problem since this is my final project. FYI the x velocity
changed to zero is at 15.3 s. Thank you John
this is my cfz file :
