Autodesk CFD Static Image not exporting the cut plane when using a custom set resolution
Dokduh
Message 1 of 1
Dokduh
Hello all,
I was wondering if anyone had a solution to this problem. I'm fairly new to using Autodesk CFD, but, I have been using it to try and simulate some natural ventilation studies. The only problem here is that upon exporting while using the "custom set resolution", the cut plane disappears and I only see the top of the model. When I export the static image using the screen option rather than a custom set resolution, the cut plane appears. Is there a way to resolve this? Attached below are the images to showcase the difference in results from both options.
Replies (0)
