Autodesk CFD - Problem with Boundary Conditions and Unexpected Flow Results
Hello everyone,
I’m currently running a CFD simulation in Autodesk CFD 2025 for a simple air duct model, but I’m having trouble getting realistic flow results. My setup includes one inlet and one outlet, with the inlet defined by a velocity boundary condition (2 m/s) and the outlet as pressure = 0 Pa (ambient).
However, after running the simulation, I noticed that the flow direction and pressure distribution don’t look right — in some regions, the velocity vectors even point back toward the inlet, which doesn’t make physical sense.
I’ve already checked for:
Mesh quality (seems fine, average aspect ratio < 4)
Correct fluid properties (air, standard conditions)
No overlapping geometry or reversed faces
👉 My question:
What are the most common causes of reversed flow or unstable velocity fields in Autodesk CFD simulations, especially when using simple inlet/outlet boundary conditions?
Is there a recommended way to stabilize the results — maybe by adjusting solver settings, mesh density, or turbulence model?
Any insight or tips from experienced users would be really helpful. I just want to understand why the flow behaves this way and how to get more realistic results.
Thank you so much!
