autodesk cfd meshing error 60/503
manaalshadab
Message 1 of 1
manaalshadab
hi! I've been trying to do a wind tunnel test on my formula 1 in schools car but cfd isn't able to generate the mesh no matter what I do. I've tried the following:
- manually cleaning up the mesh in fusion 360 (removing small faces and stuff that I could find)
- running model diagnostics (nothing looked as though it could interfere with generating the mesh)
- surface wrap (it makes my wind tunnel boundary box super detailed and leaves my car inside as a block for some reason)
- changing mesh generation settings from autosize (made the mesh finer, changed the wall factor but autodesk cfd crashed on me)
I'd appreciate if someone could walk me through on generating the mesh/helping me locate the coordinates that's causing errors (on the actual volume, the coordinates are 9.57824e-06, 7.63934, 3.91933 (1201))
@Jon.Wilde @John_Holtz@Yong.Jing
Replies (0)
