- Mute
- Permalink
- Report
I have a geometry that has several solid materials volumes and 3 fluid material volumes assigned.
I am trying to build the following mesh definition:
1. Automatic size for all geometry;
2. Select all the geometry less the 3 fluids volumes and play with the size adjustment slider;
3. Select one specific fluid volume and enable wall layer and surface refinement.
The problems that I am facing start after the point 2. Despite I had selected all the geometry less the 3 fluid volumes to play with the size adjusment, when I select them I notice that only 1 of the 3 volumes keep the adjustment slider at value "1". The others 2 volumes have their size changed.
Then, the other problem is that I can't apply wall layer and surface refinement only to a specfic volume despite I have only it selected. Only this specific fluid volume will work under turbulence conditions and will have a big impact on heat transfer, that is why I only want to apply these settings to it. To keep my mesh as simple as possible.
I may say that I click apply changes between any of those steps I refered. Any help is aprreciated!
